1. AC Question's Avatar
    I've seen that my note 7 led is dim when its not getting light hit to it. And when there is light hitting it its bright. im guessing it has something to do with the ambient sensor ?
    08-23-2016 10:54 PM
  2. AlphaTango414's Avatar
    Are you talking about your screen? It is factory set for brightness to be on auto. You can turn this off by pulling the extended notification shade down and unlocking the auto box next to the screen brightness slider bar.
    08-24-2016 02:55 AM
  1. Note 7 flickers with black screen and blue borders
    By smads in forum Samsung Galaxy Note 7
    Last Post: 12-31-2016, 11:57 AM
  2. Sync Note 7 Contact and Calendar with Tab Pro 12.2
    By rganguli in forum Samsung Galaxy Note 7
    Last Post: 08-24-2016, 08:59 PM
  3. Samsung Electronics says Galaxy Note 7 demand beats supply
    By Hurleygm in forum Samsung Galaxy Note 7
    Last Post: 08-24-2016, 08:48 AM
  4. S7 note screen Protektor falling off
    Last Post: 08-24-2016, 04:29 AM
  5. Replies: 0
    Last Post: 08-23-2016, 09:08 PM
