1. AC Question's Avatar
    I have an Asus Zenfone 2 ZE551ML.
    The touch screen started to be unresponsive some days after I replaced the digitizer, but it didn't notice it at the beginning because the problem wasn't serious. However, the following days it started to be always less responsive, and now the top part of the screen it doesn't response at all. Inexplicably, sometimes the touch screen works perfectly for some minutes, and then becomes totally unresponsive.
    The software is up to date. Have you any idea of what's happening?
    08-24-2016 12:30 AM
  2. AlphaTango414's Avatar
    Bad digitizer unfortunately or you may try checking the ribbon connection to ensure it's firmly seated.
    08-24-2016 02:40 AM
  3. giacomo zilipo's Avatar
    Thank you in advance.
    I already checked the ribbon. I also tried disconnecting and reconnecting it. The problem persists.
    I also discovered that sometimes the height of the non-responsive area of the screen changes a bit. I also noticed that sometimes it's responsive to vertical movements but not to horizontal ones, altough usually it's completely non-responsive. Do you think this could be caused by the bad digitizer quality?
    08-24-2016 01:26 PM
  1. Note 7 flickers with black screen and blue borders
    By smads in forum Samsung Galaxy Note 7
    Last Post: 12-31-2016, 11:57 AM
  2. always on screen crash
    By honda-Dave in forum Samsung Galaxy Note 7
    Last Post: 08-25-2016, 08:35 PM
  3. S7 note screen Protektor falling off
    Last Post: 08-24-2016, 04:29 AM
  4. When when i touch my samsung screen it doesn't work
    Last Post: 08-24-2016, 04:25 AM
  5. Odd problem with security feature, security pin
    By digital0verdose in forum Samsung Galaxy Note 7
    Last Post: 08-23-2016, 08:01 PM
