1. AC Question's Avatar
    So my phone has 3 malware on it that are detected by malware bytes and won´t be deleted by malware bytes. Everytime I go into to try to delete them it says these files cannot be deleted from phone.
    Factory Reset also does nothing. Please help. I want my phone to work legit.
    Thank you.
    08-24-2016 03:38 AM
  2. belodion's Avatar
    Reflashing the stock ROM may be the answer, if you're sure that you really have malware.
    08-24-2016 04:11 AM
  1. how do i get my phone out of fastboot mode
    Last Post: 08-30-2016, 05:10 AM
  2. Should you do a factory reset when doing a major Android OS upgrade?
    By PalZer0 in forum General Help and How To
    Last Post: 08-24-2016, 05:39 PM
  3. Why is my app disabled in safe mode?
    By simon2c in forum General Help and How To
    Last Post: 08-24-2016, 08:18 AM
  4. What is wrong with my LG tablet keyboard?
    Last Post: 08-24-2016, 03:18 AM
  5. Replies: 0
