Need help solving 'dm-verity' and 'efs' problems.
A
AC Question
How are:
failed to mount /efs (Invalid argument), and
dm-verity verification failed... errors solved?
Any help appreciated.
dlw
A
AC Question
How are: failed to mount /efs (Invalid argument), and dm-verity verification failed...
How are:
dlw
Note 4 N910V, Version 6.0.1. MMB29MN910VVRU2CPD1
Errors started after upgrade.
anon(632115)
4,315
Re: How are: failed to mount /efs (Invalid argument), and dm-verity verification failed...
Thank you, I replied to your first post. Download Smart Switch to your PC, run Emergency Hardware Recovery and follow the on screen instructions. You will need a USB cable to connect. Basically, your software has become corrupt
A
AC Question
Solve /efs problem
How are:
dlw
By AC Question
2,203
3 sec ago Pugs1957
I have no code.
A
AC Question
Solve /efs problem
Pugs1957
Download firmware from here Firmware for Samsung SM-N910V - SamMobile and flash using Odin
It passed but problem still exist.
I'll try 5.1.1 now.
5.1.1 installed. Have boot loop.
Seeing if I can get back to 6.0.1
OK, back on 6.0.1 with same /efs problem.
Maybe time to throw it away.
Any suggestions?
A
AC Question
Solve /efs problem
I might be able to buy another instead of repair.
Octopus boxes are expensive.
I'll check out cost of repair.
The thing works. Makes and receives phone calls.
Wifi keeps turning off. That needs solved.
But, I need root and can not get it with this /efs problem.
I've tried Kingroot many, many times trying to unlock the phone.
Simply will not work.
Many thanks for you help.
dlw
itamargs
