1. AC Question's Avatar
    On occasion I find my Google Nexus 10 dead. I try to power it up and it just shuts right back off. I place a charger on it and try to power up again and get a grey box with: Android is starting....optimizing app x of xxx. Is this normal?
    08-26-2016 06:06 PM
  2. VidJunky's Avatar
    Well first let me say allowing the device to die due to low battery power is not good for it. Some devices may call it different things but basically it sounds like it may be doing the same thing as check disc after you hold the power button on your pc . Basically scanning for corrupted data, and other issues from improper shutdown. Repeated improper shutdown can cause corrupted data and if this happens to be crucial data your device could run into some serious issues and my get to the point that a factory reset is needed, at which point you may suffer data loss.
    08-26-2016 06:52 PM
  1. Galaxy 7j apps closing
    Last Post: 11-20-2016, 01:52 PM
  2. Battery usage question
    By SonDan in forum Motorola Droid MAXX 2
    Last Post: 08-30-2016, 09:22 AM
  3. My pictures have become unrecognizable Different color lines on them
    By nickstoyz in forum Samsung Galaxy Note 7
    Last Post: 08-27-2016, 01:32 AM
  4. Note 7 after 5 days
    By stonefox801 in forum Samsung Galaxy Note 7
    Last Post: 08-26-2016, 06:55 PM
  5. New S5, put SD card from old S5 in, phone doesn't work right.
    Last Post: 08-26-2016, 05:53 PM
