1. AC Question's Avatar
    My Elephone P6000 heated up extremly around the USB port, and when I pulled out the cable, the core of the cable with the pins got separated from the shell of the head (Blitzwolf reversible cable). I let it cool down, but it won’t charge, altough I tried a bunch of different chargers. When I connect to a charger, I can fell a little heat around the USB, but the Ampere app doesn't detect any charging. If the charger has a led, the light even goes off when I connect the phone. The phone itself works perfectly, and I can charge the battery with an external charger. I only need to replace the charging board, or there could be other problems?
    08-27-2016 08:46 PM
  1. What is the cheapest option to get on the Galaxy Note 7?
    By tivoboy in forum Samsung Galaxy Note 7
    Last Post: 09-15-2016, 01:14 PM
  2. why is my phone charging so fast?
    Last Post: 08-28-2016, 04:39 AM
  3. Replies: 0
    Last Post: 08-27-2016, 08:26 PM
  4. LG Lucid 3 not charging
    Last Post: 08-27-2016, 08:21 PM
  5. The OTT TV box I just bought came rooted. Is this normal?
    Last Post: 08-27-2016, 07:53 PM
