1. AC Question's Avatar
    When I try to play music the volume was extremely low so I tried turning it up but when I hit the volume button it showed that the call volume was increasing and not media volume. I don't understand why this is happening since I haven't been in any calls for a while now. Please help
    08-28-2016 08:32 AM
  2. GRIMWALD's Avatar
    When you press the volume button, there should be an arrow button in the upper right corner of the meter gauge. Press for the drop down menu, from there you can adjust the volume for your media and system settings.
    From the main settings menu, it is possible to set the default sound levels, this way you won't have to keep increasing your media volume levels every time you play media.
    GRIM
    08-28-2016 09:13 AM
  1. How do I get my apps back
    By scorgio345 in forum HTC One Mini
    Last Post: 03-15-2017, 11:37 AM
  2. Pulled out battery during system update, now won't boot up
    By suiken01 in forum Samsung Galaxy Note 3
    Last Post: 10-31-2016, 02:35 AM
  3. Replies: 0
    Last Post: 08-28-2016, 08:01 AM
  4. how to unlock a prepaid Virgin Mobile in the USA
    Last Post: 08-28-2016, 07:58 AM
  5. Can't play music in car with lumia 550 phone, via aux cable
    Last Post: 08-28-2016, 07:53 AM
