1. AC Question's Avatar
    After 7 hours on the charger and on airplane mode my Nexus 10 will not recharge to 100%.
    08-28-2016 01:17 PM
  2. belodion's Avatar
    A bad lead? A dirty or damaged port?
    08-28-2016 02:32 PM
  3. Rukbat's Avatar
    Check the charging rate (Ampere will do it).
    If the charge rate is normal (800mA on USB, 1,200mA or more on AC), the battery is probably bad. (The tablet is 4 years old - longer than you should expect any lithium battery to last.) If the charge rate is only a couple of hundred mA, either the battery is bad (I'd still lean that way) or there could be a few other reasons - in addition to what Belodion mentioned.
    08-28-2016 02:38 PM
  1. why can't I use custom ringtones on my blackberry prove?
    Last Post: 09-07-2016, 02:44 AM
  2. Why does my display sleep when I'm on a phone call?
    By jwboulder in forum Ask a Question
    Last Post: 08-28-2016, 03:51 PM
  3. Replies: 1
    Last Post: 08-28-2016, 03:30 PM
  4. Why won't phone charge from car 12v outlet?
    Last Post: 08-28-2016, 01:44 PM
  5. My Samsung Galaxy Note 10.1 won't turn on.
    Last Post: 08-28-2016, 01:09 PM
