1. chaniafrost's Avatar
    My current lock screen type is swipe. I want to change this to fingerprint/PIN/pattern.
    But when I go to: Settings => Lock screen and security => Screen lock type
    ...it asks me for a PIN. I've tried all the relevant PINs I have created and none work. It just keeps saying "Try again". So I'm currently stuck with no security and swipe unlock.
    How do I reset this PIN and change my Lock screen type?"
    Thanks!
    08-29-2016 05:30 AM
  2. badelhas's Avatar
    Thanks!
    If there's a pin someone had to configure it or else it wouldn't ask for one. Have you tried 0000 or 1234? If you can't find it I believe the only thing that you can do is reseting the phone through the bootloader since if you try it from the settings it will ask for that pin again.
    08-29-2016 06:54 AM
  1. Replies: 2
    Last Post: 08-30-2016, 10:54 AM
  2. Replies: 1
    Last Post: 08-29-2016, 07:56 AM
  3. Note 7 top speaker for voice calls no longer works
    By AC Question in forum Samsung Galaxy Note 7
    Last Post: 08-29-2016, 06:06 AM
  4. Gear fit 2 S Health overlapping records for sleep
    Last Post: 08-29-2016, 04:54 AM
  5. Replies: 0
