1. AC Question's Avatar
    I need to set my alarm volume on loud as I can't hear it to wake me up, my phone volume is set on full, tried lots of ways but cant get to up the volume on my alarm, can someone help me , please, thanks in advance
    08-30-2016 01:32 AM
  2. the tall guy's Avatar
    Hi, if the volume is currently set to the highest point, then it won't go any higher. Usually you can adjust the volume from within the alarm app - have you checked in there to make sure the volume is right up at 100%?
    If you want to answer back and continue to work on this just join the site and participate in this thread, its easy to sign up just click here -
    https://passport.mobilenations.com/?...546.1472539107
    Sam_Gs7 likes this.
    08-30-2016 02:27 AM
  3. Sam_Gs7's Avatar
    Will help if report the Phone brand on which you Try adjust its volume
    As example. When I set my alarm on my SGs7 to 5AM : I make sure
    To increase the Phone volume to Max..Also the alarm App it has its
    own volume setting toBe loudly the 1st-60 seconds. Check out
    08-30-2016 02:28 AM
  1. Finding the newer Snapdragon S2
    By mallomar in forum Samsung Galaxy Tab S2
    Last Post: 09-08-2016, 09:50 PM
  2. Replies: 1
    Last Post: 08-30-2016, 02:03 AM
  3. unfortunately process the com.android.phone has stopped
    Last Post: 08-30-2016, 12:50 AM
  4. My Samsung E7 has charging issue
  5. Replies: 0
    Last Post: 08-30-2016, 12:32 AM
