When connected via USB: "Charging" but not option for "Connected for Charging"
A
AC Question
Hi there! So I'm trying to transfer files from my phone to my computer. I use Android File Transfer after changing my USB connection setting from my notification screen to Media Device or USB transfer.
The problem is I just got my s7 Edge and when I plug it into my laptop, the notification for "Charging" (shows you the percentage, etc) shows up but no other "Connected for Charging" option for me to click on in order to change the setting.
After a lot of searching, I couldn't find anyone with this particular issue. I can't find Developer Options or anything else either on my phone in settings in case I needed to turn something on there. I'm currently running 6.0.1 if that helps.
Help! Thank you in advance!
wei34
