1. Pavlex4's Avatar
    I have Samsung galaxy s3 neo.OTG cable and otg ir remote device worked fine and after few days it won't detect my otg cable and otg ir remote device until I pull otg cable little up and hold it and some time when I connect otg cable it says usb connector connected and usb connector disconnected and repeat that many times.
    How to fix this?
    I tried using another otg cable and still have problem.I don't have problem with usb charger.
    Data transfer between PC and Android is working fine.
    09-01-2016 03:06 PM
  2. sulasno's Avatar
    Try using another cable
    09-01-2016 04:33 PM
  3. Pavlex4's Avatar
    09-04-2016 04:21 PM
  4. sulasno's Avatar
    Re check developer's options?
    09-04-2016 05:45 PM
  5. B. Diddy's Avatar
    You mention no problems with the USB charger--but what about the data transfer connection with your PC if you connect via USB? If it's constantly connecting and disconnecting to the PC, then I'd suspect some problem with the port--specifically with the data transfer contacts (which are separate from the charging contacts).
    09-04-2016 07:04 PM
  6. Pavlex4's Avatar
    09-06-2016 10:59 AM
  7. B. Diddy's Avatar
    Hmm. The fact that you have to adjust or jiggle the plug still suggests a problem with the connection. Use a can of compressed air to blow out the microUSB port, in case there's some debris in there getting in the way.
    09-06-2016 03:36 PM
  1. how to delete a contact?
    Last Post: 09-01-2016, 09:34 PM
  2. How to get theme back
    Last Post: 09-01-2016, 02:26 PM
  3. Why won't my HTC One M8 backup to HTC Sync?
    Last Post: 09-01-2016, 01:58 PM
  4. Why won't my HTC One M8 backup to HTC Sync?
    Last Post: 09-01-2016, 01:55 PM
  5. motorola phone android 6 trying to change DNS
    Last Post: 09-01-2016, 01:18 PM
