1. AC Question's Avatar
    The last two weeks or so my Samsung S7's battery has been draining very quickly, when I go into Battery Usage, "Android System" and "Android OS" have often used up to 40%.
    Is there anything I can do to fix this, or something I can switch off to prevent it from chomping so much battery?
    09-06-2016 11:20 AM
  2. belodion's Avatar
    Try first a Power Off and Restart. If no go, try a Cache Partition wipe.
    If still no go, get back to us.
    09-06-2016 12:07 PM
  3. UrsulaOtto's Avatar
    What is a cache partition wipe? Sorry, dumb blonde!!!
    09-06-2016 01:54 PM
  4. belodion's Avatar
    Welcome as a new member.
    Here's how to do it on the S7, with thanks to T-Mobile:
    https://support.t-mobile.com/docs/DOC-30240
    09-06-2016 03:14 PM
  5. UrsulaOtto's Avatar
    Thank you so much!!!! I just joined, but this is not the first time you guys have helped me out!!! Really appreciate it!!!! 😉
    belodion likes this.
    09-07-2016 06:27 AM
  1. Fuzzy and Fading Lines on LG G2 Screen
    By Maya2627 in forum LG G2
    Last Post: 09-06-2016, 11:39 AM
  2. Low Res Contact Photos and Dialer
    Last Post: 09-06-2016, 11:08 AM
  3. Nexus 5x still didn't receive android N update
    Last Post: 09-06-2016, 10:54 AM
  4. Weird behaviour of quick settings ui in Android Nougat
    By Abhay Nanal in forum Android 7.0 Nougat
    Last Post: 09-06-2016, 10:04 AM
