1. AC Question's Avatar
    I've been using the standard issue charging cable and base that came with the phone for well over a year with no problems and all of a sudden I plug in my phone and it's not charging. I swap out cables in case it has gone bad but the same thing happened. I then tried two different bases with no luck. Finally I plugged the cable into the computer and it started charging. Why??? I can't live off of a slow pc charge. How can I fix this?
    09-13-2016 05:00 PM
  2. TenshiNo's Avatar
    First, plug in a lamp or something to the same outlet and make sure it's not a case where you have lost power to the outlet. If that works, it might be a specific combination of chargers/cables. Without knowing exactly which steps you took, I can't offer more. From the sounds of it, I'm leaning towards it being a lack of power to the outlet, although it's possible that it's because the original cable has gone bad and the other cables you tried are low quality or incompatible in some way with the device.
    09-13-2016 05:33 PM
  1. Replies: 1
    Last Post: 09-14-2016, 01:16 PM
  2. Why won't my LG Risio turn on?
    By zachwilsone in forum Ask a Question
    Last Post: 09-13-2016, 10:49 PM
  3. Replies: 4
    Last Post: 09-13-2016, 06:59 PM
  4. Replies: 1
    Last Post: 09-13-2016, 06:13 PM
  5. Replies: 0
    Last Post: 09-13-2016, 04:20 PM
