Why won't my camera work? Message says camera has stopped. How can i turn it on?
anon(9983233)
652
Locate the camera app within your settings > app manager Once located force stop/disable or even uninstall.. The uninstall option can be done through your main screen by tab/holding the app until the screen goes gray and a uninstall appears or delete appears at the top of the screen. Once you've isolated and or removed the app. Locate the app once again via the Google play app store.. But this time, try several camera apps which offer you more options and a wide range of features.
ThatDude
