1. AC Question's Avatar
    I have a new S7 in which I have updated the firmware to Marshmellow 6.0.1. I can connect to mobile data and to a local free wifi with no problem, but I cannot connect to my work wifi systems - either secured or unsecured. I have tried all the usual things like clearing cache, forgetting networks, all bluetooth settings are turned off, etc. What usually happens is that when I try to connect the circle thing just keeps turning for as long as I bother waiting, but it doesn't connect. My old motorola moto g connects to all the networks instantly. There are about 50 other cellphones connected with no problems and also some other S7s. Any ideas what the problem with my phone might be? I am getting close to sending it back to the shop for a refund.
    09-17-2016 06:24 AM
  2. the tall guy's Avatar
    Hi, did you find a resolution to this issue? does the phone connect to other wifi signals - is it just the works one that doesn't work?
    09-22-2016 04:37 AM
  1. Galaxy S7 vibrations
    By xacheron in forum Samsung Galaxy S7
    Last Post: 10-14-2016, 09:38 AM
  2. Somebody has to say it - My biggest Fear about the New Note 7
    By kabeeo in forum Samsung Galaxy Note 7
    Last Post: 09-17-2016, 10:21 AM
  3. Replies: 1
    Last Post: 09-17-2016, 06:12 AM
  4. if I clear my cached data will I lose apps and contacts
    Last Post: 09-17-2016, 05:40 AM
