1. AC Question's Avatar
    There used to be a sound path setting on my norification banner, even though I didn't switch the settings it's not there anymore. Does anyone know how to get it back or another way to switch the sound output between the phone speakers and bluetooth headphones?
    09-19-2016 09:17 PM
  2. Tbayrgs's Avatar
    I have the same question. I find no way to change the audio output destination in any of my apps, but primarily Google Play Music and Pocket Cast unless it's to a Chromecast. I could've sworn it existed in the past but can't find the option anywhere. To clarify, for example, in those same apps in iOS, if I touch the AirPlay icon, I can select from the phone speaker, any AirPlay compatible device in range, or any connected bluetooth device. This is in addition to the Chromecast option. On Android--nothing like it. If I want to switch from a bluetooth speaker to the phone or vice-versa, there appears to be no simple way to do this. This seems bewildering to me.
    I hope I'm just being daft and missing it. Appreciate insight from anyone that can help. BTW, I'm presently using a Pixel XL if that matters for any reason.
    10-28-2016 10:17 AM
  1. Replies: 29
    Last Post: 09-21-2016, 10:39 AM
  2. Replies: 1
    Last Post: 09-21-2016, 01:29 AM
  3. Replies: 1
    Last Post: 09-19-2016, 09:59 PM
  4. Replies: 1
    Last Post: 09-19-2016, 09:54 PM
  5. Where are the settings for immersive mode on Marshmallow?
    By mwbryant1977 in forum Android 6.0 Marshmallow
    Last Post: 09-19-2016, 08:45 PM
