1. AC Question's Avatar
    I reset my alcatel onetouch fierce xl and now it only goes to "wifi connection",so I connect with the nearest wifi network only to get a "couldn't connect to the internet", and it won't go or do anything else. Somebody please help,i'm ready to slam this thing on the ground!!!
    09-22-2016 11:45 AM
  2. the tall guy's Avatar
    Hi, make sure you are close to the WiFi router - make sure no other device is connected to it and try again. You need to have a strong and stable connection in order to complete the process.
    09-29-2016 08:43 AM
  1. No Samsung Account - Reset Will Brick the Phone
    By jebber in forum Samsung Galaxy S6 active
    Last Post: 09-23-2016, 03:42 AM
  2. After doing a factory reset how do I reactivate my phone
    Last Post: 09-22-2016, 01:06 PM
  3. I can't used my SD (internal) after made factory data reset
    Last Post: 09-22-2016, 07:08 AM
  4. Sound setting problem
    Last Post: 09-22-2016, 12:13 AM
  5. Verizon store problems
    Last Post: 09-21-2016, 10:16 PM
