1. AC Question's Avatar
    I had the fingerprint and battery performance drop after I updated my phone (6p) to Android N. I cleared the cache partition, and that didn't help. I am pretty sure I don't have an app that consumes that much battery. Is it just me or someone else is experiencing it? Also, every time when I get a system update, I get two (same) notifications. I always have problem with major android update. Getting very frustrated!
    09-24-2016 08:12 PM
  2. belodion's Avatar
    Do your battery usage stats offer any clues at the end of a day's use?
    09-25-2016 06:11 AM
  3. anon(9983233)'s Avatar
    I would suggest that you test the Opera Max app which can help you better adjust and minimize those apps when tend to draw more from the battery when not in use. Opera Max can also eliminate or isolate those apps which are not import or simply running in the background in order to save data usage.
    09-25-2016 08:34 AM
  4. Tim1954's Avatar
    You may want to wander through your settings /preferences again too....
    09-25-2016 01:51 PM
  1. Replies: 2
    Last Post: 10-01-2016, 11:05 AM
  2. software update warning on screen
    Last Post: 09-25-2016, 06:18 AM
  3. Galaxy S7 shuts down before battery runs out
    By dislab in forum Samsung Galaxy S7
    Last Post: 09-24-2016, 08:59 PM
  4. how can i transfer my music from my phone to my sd card?
    Last Post: 09-24-2016, 07:35 PM
  5. Replies: 0
    Last Post: 09-24-2016, 05:44 PM
