1. AC Question's Avatar
    My phone's system is inconsistent. the system UID is malfunctioning
    09-26-2016 12:56 PM
  2. Jerry Hildenbrand's Avatar
    Look for the file /data/system/uiderrors.txt
    This will be an actual list of the apps with mismatched user IDs versus the generic message you are probably seeing in the pop-up box. Try uninstalling then reinstalling them.
    If you're rooted, you can try a custom recovery that has a UID mismatch fix in its settings.
    09-26-2016 01:03 PM
  1. Can Only Unlock Phone w/Backup Password After MM Update
    By Brew Swayne in forum Samsung Galaxy Note 4
    Last Post: 09-29-2016, 01:56 PM
  2. how to unlock verizon samsung galaxy 4s note to cricket
    Last Post: 09-26-2016, 12:54 PM
  3. Motorola Mini Droid - how to set custom ringtone
    By catcha22 in forum Motorola Droid Mini
    Last Post: 09-26-2016, 12:47 PM
  4. How can I tell which notifications are set to which apps?
    Last Post: 09-26-2016, 12:36 PM
  5. How do I restore my original keyboard for the Samsung 4
    Last Post: 09-26-2016, 12:22 PM
