1. AC Question's Avatar
    Updated to marshmallow and now the most I can charge my tabs is at 87%, won't go any higher. Once it showed that I had 100% but when I turned it on, 87%. Any suggestions? Any one else? thanks
    09-27-2016 04:12 PM
  2. onnad's Avatar
    Welcome to AC. Which device do you have? Can you check the charger on another device to see if the charger itself is possibly faulty?
    B. Diddy likes this.
    09-27-2016 04:35 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Also, what happens if you leave the device plugged into a wall outlet overnight? Still only 87%? You could try recalibrating the battery sensor software by using it normally until it shuts off automatically from low battery, then charging back up again overnight. Does it hit 100% now?
    09-27-2016 04:41 PM
  4. jwvrod's Avatar
    Forgot I had an account, oops. I have used three different chargers, left overnight, all with the same result, 87%. Guess I'll try to let it die on its own and see what happens.
    09-27-2016 05:26 PM
  5. B. Diddy's Avatar
    Which device do you have? If possible, try wiping the cache partition.
    09-27-2016 11:29 PM
  1. When is the relaunch of the Note 7 in Canada?
    By Sailor Webber in forum Samsung Galaxy Note 7
    Last Post: 09-29-2016, 08:17 AM
  2. charging the Galaxy S6
    Last Post: 09-27-2016, 06:14 PM
  3. why is my samsung tablet draining in a half hour of use
    Last Post: 09-27-2016, 04:47 PM
  4. Why does my music volume button shut off automatically
    Last Post: 09-27-2016, 03:31 PM
  5. Replies: 0
    Last Post: 09-27-2016, 03:22 PM
