1. AC Question's Avatar
    Device name is Asus zenfone 2 laser. Ican only use it by putting in charge
    09-30-2016 02:57 AM
  2. belodion's Avatar
    The battery may need replacing, or there may be some internal fault.
    09-30-2016 06:01 AM
  1. lg g5 battery option
    By bucbans in forum LG G5
    Last Post: 10-01-2016, 09:53 AM
  2. Where is the sensor that turns the AOD off in your pocket?
    By Snareman in forum Samsung Galaxy Note 7
    Last Post: 09-30-2016, 02:56 PM
  3. how do i check my samsung interner from my cell on my pc
    Last Post: 09-30-2016, 01:31 PM
  4. Android not installing?
    Last Post: 09-30-2016, 02:18 AM
  5. Replies: 1
    Last Post: 09-30-2016, 02:09 AM
