1. AC Question's Avatar
    So my s6 edge fell into the toilet bowl I tried to take it out immediately but as I took out it, it already turned black. it fell from quite a distance
    I have submerged it in rice. Is there anything else i can do to increase the chance of it surviving?
    10-04-2016 11:21 PM
  2. belodion's Avatar
    At this point, probably not. You could try the alcohol method, or leave it in the rice for several days. Either way, it may or may not work again, and if it does, it may be only temporary.
    See this:
    [GUIDE] Oh, no! My Phone got Wet!
    https://r.tapatalk.com/shareLink?url...0&share_type=t
    10-05-2016 06:29 AM
  3. Rukbat's Avatar
    Remember, it's water resistant (not waterproof) if it's in water, but not if it's dropped into water. (The initial drop can force water past the seals. IOW, IP67 is an advertising gimmick.)
    belodion likes this.
    10-05-2016 02:57 PM
  1. Replies: 1
    Last Post: 10-05-2016, 07:22 PM
  2. Battery Drain drastically on moto g4 plus
    Last Post: 10-04-2016, 11:19 PM
  3. How to buy Axon 7 in india
    By Allan Dsouza in forum Axon 7
    Last Post: 10-04-2016, 11:06 PM
  4. What does the star symbol mean on my ALCATEL onetouch mean
    Last Post: 10-04-2016, 10:44 PM
