Is there a way to make the volume control on an S7 also control a Bose dock?
  • Start date Start date
A
AC Question
Hi, I have recently bought an S7 and am finding it a bit annoying that when playing music (or anything) on it through a dock (for example a Bose Soundtouch) you have 2 different volumes. The media volume on the phone, and then in addition the device volume.
For example on other handsets, when you change the volume on the phone, it controls the volume on the dock as well. So there is only ever one volume.
At the moment I am having to turn one up - and then the other - or vice versa depending whos coming!!
Was just wondering if there was a way to set the android as the master volume controller ?
liquidsnake757
