1. AC Question's Avatar
    Currently, my car has the base for a mount drilled into it. It is for a Sirius radio player, however I have no use for the player. The base has one of those pivot balls on the end. Does anyone know of a phone mount/charger that will accommodate the pivot ball? I also have a ZeroEdge wireless charger/holder that has a single T slot. If there is some sort of mount converter out there that take the pivot ball on one side and T slot on the other, that would work too.
    10-13-2016 10:34 AM
  1. ZW2 chimes while sitting on charger
    By NealJ777 in forum ASUS ZenWatch 2
    Last Post: 12-26-2016, 10:23 AM
  2. HELP: Note 3 won't factory reset after recovery image mess up
    By Nekusta in forum Samsung Galaxy Note 3 Rooting, ROMs, & Hacks
    Last Post: 10-16-2016, 08:54 AM
  3. Not much experienced at Digital Parenting, Need Help!
    By Alex Derek in forum General Help and How To
    Last Post: 10-14-2016, 06:10 AM
  4. Replies: 1
    Last Post: 10-13-2016, 09:16 AM
  5. Replies: 0
    Last Post: 10-13-2016, 08:38 AM
