1. AC Question's Avatar
    My friend is coming from US so planning to buy s7 edge. There are so many s7 edge models present in Amazon.com am confused which one will work in india
    Which S7 edge model I should buy in US so that it will work in India with 4G LTE connection and VOLTE.
    If possible share Shopping site link. Thanks in advance.
    10-14-2016 09:20 AM
  2. anon(632115)'s Avatar
    I suggest you go here WillMyPhoneWork.net - Check if your phone works on a network It will help you choose the correct device for the network you want to use it on.
    If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
    pradeepchinna likes this.
    10-14-2016 09:37 AM
  3. pradeepchinna's Avatar
    I already gone through that link but for every model it is showing it will work in India in LTE am not sure about that.. Also what about VOLTE
    10-14-2016 10:00 AM
  4. anon(632115)'s Avatar
    Here's a bit of reading for you [Firmware] Reliance JIO on S7 Edge VoLTE not working
    Bottom line seems to be you need the correct CSC so will need to flash new firmware plus that firmware needs to support VOLTE
    10-14-2016 10:19 AM
  5. pradeepchinna's Avatar
    Please forgive if it is dumb question
    Is this applicable to even s7 edge that is bought in US or may be only to the phones that is sold in India
    10-14-2016 10:23 AM
  6. anon(632115)'s Avatar
    Yes but naturally you will need the unbranded international version. With devices purchased in India, the CSC code wouldn't be an issue.
    BTW, no question is a dumb question
    10-14-2016 10:26 AM
  7. pradeepchinna's Avatar
    10-14-2016 12:02 PM
  8. anon(632115)'s Avatar
    Both look fine but check there is an Indian csc variant for the FW you will need to flash. Just check firmware on Sammobile to confirm
    10-14-2016 12:32 PM
  9. pradeepchinna's Avatar
    Seriously I didnt understood what you said in previous comment can you do that for me thanks in advance
    10-14-2016 12:39 PM
  10. anon(632115)'s Avatar
    Sure. To get VOLTE working it seems like you need firmware that carries the CSC code for India. I have looked and there is none for the S7 Edge.
    10-14-2016 03:06 PM
  11. pradeepchinna's Avatar
    SO you mean to say I cannot use VOLTE in S7 edge in India . I got this link can you check once
    s7 edge duos csc code change - Page 2
    10-14-2016 09:59 PM
  12. anon(632115)'s Avatar
    Just read it. Looks as tough you will need to join the site but post 42 seems to include a link to the firmware. Go and grab it and guard it with your life. I think you have a new phone to look forward to
    10-15-2016 03:26 AM
  1. Replies: 8
    Last Post: 10-17-2016, 03:19 PM
  2. Replies: 2
    Last Post: 10-14-2016, 09:10 AM
  3. my lg ms323 is stuck on boot loop how do i fix it
    Last Post: 10-14-2016, 08:58 AM
