1. AC Question's Avatar
    OKay i have a less than year old note 5
    i dropped it on carpet after the battery died.
    Problem. does not power on, i have Blue Led.
    I charged for 10 hours no help BUT while charging LED turns RED/orange.
    I tried volume down and power button (along with every other combo possible) for upwards of 2 min. each.
    Sprint refuses to work on it
    10-18-2016 07:32 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! See this thread, which discusses the issue on the S6. My Samsung S6 won't turn on - Blue light stays on.what could the problem be?
    10-18-2016 08:02 PM
  3. Mariah Vela's Avatar
    Hi, did you get it working again? What did you do? I'm having the exact same problem
    03-09-2017 09:38 PM
  1. The Note 5 should be updated and released as the Note 6
    By Sothpaw66 in forum Samsung Galaxy Note 7
    Last Post: 10-19-2016, 09:55 AM
  2. Stuck on Lock Screen on GS7 (no keyboard)
    Last Post: 10-18-2016, 10:59 PM
  3. why cant i factory reset on lock scree
    Last Post: 10-18-2016, 06:59 PM
  4. K5 Vibe Plus LED Notification and Software Update Problem
    Last Post: 10-18-2016, 06:41 PM
  5. HTC M9 Stuck on SafeBoot Screen with no power button
    Last Post: 10-18-2016, 06:16 PM
