1. AC Question's Avatar
    My Samsung Galaxy A3's battery life drains really quickly after upgrade to Android 6. Even if i power off after charged, my phone battery can still drop to zero without power on. Im pretty sure my phone battery has at least 60-70% b4 i turn it off.
    How to solve tis problem? Pls help.
    10-24-2016 07:01 PM
  2. the tall guy's Avatar
    Hi, can you try performing a factory reset on the device and letting us know if that helps? it's usually recommended after a big software update.
    If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
    10-31-2016 09:16 AM
  1. Pixel curved screen and tempered glass problem
    By maxburn in forum Google Pixel Accessories
    Last Post: 03-30-2017, 03:41 PM
  2. extended battery case
    By Crabby Abie The Queen T-Flo in forum LG G5
    Last Post: 11-14-2016, 01:10 PM
  3. My android phone wont open after freezing
    Last Post: 10-31-2016, 08:24 AM
  4. Why is my Kindle Fire not connecting to the server>
    Last Post: 10-24-2016, 07:38 PM
  5. Is it possible to flash ROM using windows command?
    By fullscore21 in forum Ask a Question
    Last Post: 10-24-2016, 06:26 PM
