1. AC Question's Avatar
    ok so i just recently bought a Samsung Galaxy S7 Edge and a wireless charging stand. The S7 Edge works just fine but one thing I'm noticing is that the wireless charging stand takes some time to charge my phone. I say this because my phone needed 30 percent to be fully charged and it said it would about 43 minutes to charge. That seems unusually high for me considering it's supposed to be a "fast charge." Does this seem normal to you guys or is my product defective? Before you ask, it is using the original cable, my phone settings are as they should be (the option for fast wireless charging is on) and it is connected directly to an outlet. Any help would be greatly appreciated.
    10-30-2016 05:48 PM
  2. chanchan05's Avatar
    Well, wireless charging is slower than wired charging. Wireless fast charge just means its faster than normal wireless charging.
    You also have to take into account if there is anything running or syncing at that time.
    10-30-2016 09:00 PM
  1. Replies: 36
    Last Post: 10-31-2016, 06:17 PM
  2. my samsung is syuck on down load after i locked myself out
    Last Post: 10-31-2016, 12:49 PM
  3. Is Blackberry Priv still good enough at its price ?
    Last Post: 10-30-2016, 08:27 PM
  4. Is it worth buying?
    By venom0706 in forum Samsung Galaxy S7 edge
    Last Post: 10-30-2016, 07:23 PM
