The battery is non-removable, which means that you opened the phone. You probably unplugged a few cables or moved them - which led to the screen problem.
Now you'll have to bring it to a shop that will work on a device you've already opened (many won't), pay them to fix the damage you caused, then pay them to fix the original problem.
Next time, bring it to a shop first.
