1. AC Question's Avatar
    I have had my S7 Edge since the day it came out. Of that time I have noticed that WIFI is.....not right.
    When I am driving away from my house, it has issues dropping the WIFI and switching to LTE. I am well out of range, blocks away before it drops and the phone is laggy or frozen until it does.
    Also at work, we have many APs. When I walk down the hall switching from one AP to another is bad. Complete Internet drops and has to reconnect. This did not happen on my Droid Turbo or any other device (iPads\iPhones\Chromebooks\Laptops) that are used here. The phone also gets laggy during each switch, which happens often if I am walking down the hall. Switching APs on the same SSID should be seamless.
    Am I the only one?
    11-17-2016 10:39 AM
  2. VW Maverick's Avatar
    11-17-2016 11:32 AM
  3. Evan Sullivan1's Avatar
    Hello and thank you. Sorry I forgot to log in before I posted, I am the OP.
    The ones in there that I can so, I have already tried to no avail. I have issues not only with my home network but my work network as stated. I cannot make changes the wireless settings at work.
    11-17-2016 12:16 PM
  4. Evan Sullivan1's Avatar
    I guess I am the only one having these issues?
    11-29-2016 08:19 AM
  1. Galaxy S7 Edge WiFi Turning Off and On Repeatedly
    By Nic Zibelli in forum Samsung Galaxy S7 edge
    Last Post: 04-20-2017, 10:07 AM
  2. Wifi on then off - constantly
    By ClintRo in forum Samsung Galaxy S7 edge
    Last Post: 11-24-2016, 01:05 PM
  3. Turn off wifi causes reboot
    Last Post: 11-21-2016, 09:30 PM
  4. Replies: 0
    Last Post: 11-17-2016, 10:22 AM
  5. Google search widget issue
    By Dr Nortz in forum Android 6.0 Marshmallow
    Last Post: 11-17-2016, 09:57 AM
