Hey there! Just got the LG V20 and was wondering: how long does it take to fully charge the battery the first time? Thanks for you help & Happy Thanksgiving! Tommy S.
Well since you have it... you will eventually find out. It's going to be very soon you're not that far away.
It depends. It will be different for ever other user. How are you charging it? Are you using it while charging? Background apps? How many apps? Etc... depends on so many different things...
