1. AC Question's Avatar
    Hey there! Just got the LG V20 and was wondering: how long does it take to fully charge the battery the first time? Thanks for you help & Happy Thanksgiving! Tommy S.
    11-18-2016 01:31 AM
  2. 420lyfe's Avatar
    Well since you have it... you will eventually find out. It's going to be very soon you're not that far away.
    It depends. It will be different for ever other user. How are you charging it? Are you using it while charging? Background apps? How many apps? Etc... depends on so many different things...
    11-18-2016 02:26 AM
  1. Want to restore device to stock OS HTC One M8
    By Kaboom0 in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 11-19-2016, 06:13 AM
  2. How to recover erased S Note data from a Galaxz Note 4?
    Last Post: 11-18-2016, 12:58 AM
  3. Replies: 0
    Last Post: 11-17-2016, 11:36 PM
  4. How to set default Ringtone and notification sound volume
    Last Post: 11-17-2016, 11:35 PM
