1. AC Question's Avatar
    Ok, So I bought the S4 in the summer, and its never had a good battery life, but now its so bad it only lasts 3 hours max. I have tried so many things, a factory reset, closing all my applications and power saver mode, it doesnt seem to work. I went out and bought a new battery today and the phone is draining this one even faster! Every minuet it goes down a percent with me not doing anything on it. It also charges very slowly now, taking more then 8 hours for a full charge. I am wondering if there is anything else I can do.
    11-20-2016 07:20 PM
  2. Tim1954's Avatar
    Do you know what's draining it? On battery app you should get a breakdown of what apps are using power and how much.... That is abnormally fast so you may have a rougue app or some fault in the device...
    11-20-2016 10:16 PM
  1. Replies: 2
    Last Post: 11-21-2016, 01:08 PM
  2. Will the DAC play through bluetooth?
    By talon1189 in forum LG V20
    Last Post: 11-21-2016, 08:22 AM
  3. Is this normal battery life???
    By Zyphen4866 in forum Samsung Galaxy S7 edge
    Last Post: 11-20-2016, 08:59 PM
  4. Is the samsung tab 3 in the 7" variant support otg?
    Last Post: 11-20-2016, 07:12 PM
  5. New V20 user.
    By freightguy1979 in forum LG V20
    Last Post: 11-20-2016, 07:00 PM
