1. justwondering's Avatar
    Hi , I have a oneplus 2 phone , in general it is working great.........BUT my battery stats are not reporting correctly.
    Okay I have tried the fully discharge , fully recharge method etc etc......
    So I thought perhaps fully charge the phone to 100 percent , then do a full reset ( But Will this reset my battery stats ??)
    Or I have two options when turning the phone on with power pressed and volume down.....
    1) Wipe data
    2) Wipe cache
    Ideally I do not want to fully reset my phone it is set up just nice and how I like it.....BUT the battery thing is niggling me too much...
    I know the battery is not faulty because if I follow this procedure the battery is great all day....fully charge , then let it run down say a few percent , put it back on charge and it takes a while to charge and then the percentage drops down normally.
    11-23-2016 11:37 AM
  2. Javier P's Avatar
    Duplicate. Please, refer to your other thread.
    How to reset battery stats on phone with no root ? I have a few options Help Please
    Thread closed to avoid parallel discussions.
    11-23-2016 11:43 AM
  1. Replies: 2
    Last Post: 12-27-2016, 09:03 PM
  2. best time to up the data?
    By pure1500 in forum AT&T
    Last Post: 11-24-2016, 04:14 AM
  3. Replies: 1
    Last Post: 11-23-2016, 11:42 AM
  4. Problem with volume button!
    Last Post: 11-23-2016, 11:30 AM
  5. Phone recommendation needed (Nexus 5 to ???)
    Last Post: 11-23-2016, 11:19 AM
