1. AC Question's Avatar
    Dear Sir,
    I have rooted my phone once and installed busybox. After using busybox i uninstalled it. Then again one day i needed to install busybox. I then switched off my phone at night and the next day when I tried turning on my phone, It just shows the ASUS logo and then a USB logo and then turns off by itself, nothing happens from there. It can't even go to recovery nor does it boots up. What should i do?? I tried installing ROM through xFSTK, but it also shows errors and ends up as unsuccessful, please help me with a solution. I love my phone a lot, and I want it back to life.
    ASUS Zenfone 6 it is.
    11-26-2016 06:59 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. You may have to consider getting a JTAG device to revive your phone. There is no guarantee this will work though.
    11-26-2016 09:25 AM
  1. Replies: 22
    Last Post: 12-02-2016, 11:23 PM
  2. Spyware Expert Needed
    Last Post: 11-27-2016, 04:13 PM
  3. Screen will not come on
    Last Post: 11-26-2016, 05:08 AM
  4. Why my sd card cant be detected
    Last Post: 11-26-2016, 04:52 AM
  5. Triangle sideways on notification bar
    Last Post: 11-26-2016, 04:29 AM
