1. AC Question's Avatar
    This issue is relating to music bought from google store.
    On the top of my home screen I have a caution symbol and when I pull down the menu the detail reads "can't download music, not enough space."
    When I click the detail I am forwarded to a download queue where 4 songs I've bought are showing with a grey download symbol next to each.
    Clicking on the download symbol prompts the following message:
    Storage Unavailable
    The selected storage device has been removed. To keep music, please insert the storage device or select a different download storage location from settings.
    To clarify, the SD card is inserted and has 66gb of free space available.
    So following the instructions given by this message I go to settings > storage > SD card. The only options are unmount and format. So I can't do what the message told me to which I find stupid.
    Next I tried unmounting the SD card and re-inserting it. I formatted the card. I made sure I was signed into the same account I used to purchase the song. I then deleted a song in an attempt to re-download it.
    None of this fixed the issue and the song I deleted now won't sync even though the store recognises I purchased it with my account. It just says "your music is being added, please wait a moment or try again." Well, three hours is a long moment.
    Try various searchs for help and cannot find anything on my particular issue. Any help would be greatly appreciated before I hurl my phone at the wall.
    Thanks.
    11-26-2016 05:07 PM
  2. srkmagnus's Avatar
    I'm pretty sure the music stores to the internal SD card. How much memory do you have there? Go into system settings - storage.
    11-26-2016 05:12 PM
  1. Any news on a updated version
    By badMojo69 in forum Samsung Galaxy Note Pro 12.2
    Last Post: 02-26-2017, 04:42 PM
  2. how do you change the alarm sound on LG K10
    Last Post: 11-26-2016, 05:31 PM
  3. Replies: 1
    Last Post: 11-26-2016, 05:19 PM
  4. Brand new screen doesn't turn on after replacement
    By erinspice in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 11-26-2016, 04:11 PM
