1. Service Videocreativ's Avatar
    Hi. I heave replaced the battery of the tablet to fix the problem. The problem is: Not charging with original charger (2000 mA), but charge with 2500 mA. The battery drains from 100% to 50% in 2 minutes then to 0% in 2 minutes. The battery is new. I supose that i heave to replace the Power Management IC Chip MT6323GA, but i am not sure the consumption is from the chip. Thank you for your help if anyone try to answer me. Today i measured the voltage and seems that the voltage that reaches at the battery for charge is 3 v. The battery is for 3,7 v. So i think that it must be almost 4 v to charge...
    12-06-2016 12:13 PM
  1. Themed face Google fit - How to display miles?
    By arsenal74 in forum TAG Heuer Connected
    Last Post: 04-23-2017, 04:56 PM
  2. Replies: 1
    Last Post: 12-06-2016, 02:01 PM
  3. Replies: 0
    Last Post: 12-06-2016, 11:49 AM
  4. Why cant't i respond to group text?
    By erin kirby in forum Samsung Galaxy Note 5
    Last Post: 12-06-2016, 11:14 AM
