A
AC Question
A quick question. There are multiple posts about trying to connect multiple devices via bluetooth but havn't found any about issues with the "calls" portion of the pairing.
When I am at home, my Nexus5 (latest OTA firmware, non rooted) will pair with my home wireless phones via BT so I leave my N5 on the charger and if a call comes in, all the wireless phones in the house will ring. In itself, that is fine.
The issue is when I add the car to the mix. The car also has BT and can handle calls. As I leave home, the car will pair audio/media but since the home wireless phones are still connected (as they are still in range), the car will not handle calls. As I drive away, the home phones are out of range but the car still won't have taken over for calls. I have to re-pair manually (cycle BT off/on).
The same will happen as I drive back home, before shutting off the car, the home wireless phones will attempt to pair but won't as my N5 is still paired to the car. Then again I will need to cycle BT off/on to force a reconnect for it to work.
Any solutions to this issue?
Thanks in advance!
Thanks in advance!
