1. AC Question's Avatar
    Android security patch level Dec 1, 2015
    Kernal 3.10.49-g888eb8b3 hudsoncm@ilclbld34#1 Dec 8 2015
    system ver 24.11 osprey_retus.en US
    Build number MPI 24.65-25
    12-08-2016 06:18 PM
  2. jeffhaskins's Avatar
    Did you adopt it as internal storage, leave it external, or does anything at all happen when you put it in?
    12-08-2016 06:24 PM
  3. kafka45's Avatar
    nothing happens....... phone acts like there IS no sdcard in the slot. I've tried various sizes 4gb 8gb..etc and different formats FAT..exFAT.. NTSF.. nothing.
    On settings-storage & USB screen, it reads Android OS 3.46 GB Internal storage 3.97 GB used of 4.54 GB. NO external storage even listed (with a card installed)
    thanks.....
    12-10-2016 12:21 PM
  4. Rukbat's Avatar
    If you formatted the card outside the phone (like on a PC), check it on that device, because the card could be bad. Or the card port on the phone could be bad. But if you formatted it as internal storage on the phone, first format it as external storage (if the phone will format it). A card formatted as internal storage isn't logically a "card", it's just "storage", the same as internal storage - and it doesn't show as a separate device.
    12-10-2016 01:04 PM
  5. kafka45's Avatar
    ok... the phone does not see ANYthing I put in the card slot. No extra storage shows up when inserted... internal OR external. I can't format (with the phone).. what doesn't exist to it. I've done read/writes to the various cards on my PC to make sure they work. I'm hoping the card slot is not bad..but that seems to be the only answer unless rooting and a diff OS (5.1 maybe),, would make a diff. I'm about ready to chuck it and go with an Iphone...
    12-10-2016 03:40 PM
  6. Rukbat's Avatar
    Rooting and a different OS (assuming that there's nothing wrong with the current one) won't change a thing.
    12-10-2016 05:05 PM
  7. kafka45's Avatar
    I figured.....but just thought I'd ask. Time to go with a different phone.
    12-12-2016 12:55 PM
  8. belodion's Avatar
    Not a repair?
    12-12-2016 01:00 PM
  9. kafka45's Avatar
    I see the part is $13 from Amazon/ with tools. I guess its time to crack this thing open and see if I can still do electrical crap. (I built a Heathkit computer from a kit in 1983)....
    12-12-2016 05:46 PM
  1. Recovering Photo and video from encrypted SD Card
    Last Post: 01-09-2017, 03:44 AM
  2. Android 7.1.1 update and Samsung pay
    By creekwater1482 in forum Samsung Gear S3
    Last Post: 12-12-2016, 07:18 AM
  3. Replies: 2
    Last Post: 12-09-2016, 07:26 AM
  4. Tap & go restore not recognizing my current device
    Last Post: 12-08-2016, 06:04 PM
  5. How do I fix error unfortunately bluetooth share has stopped
    Last Post: 12-08-2016, 05:50 PM
