1. AC Question's Avatar
    I have a Samsung Galaxy s6 Active. The past few days, I will be on my phone and I will get a battery low message. It says it is at 7%. I plug the phone in to charge it and it pops back up to 40 some %. Not really understanding what is going on with it.
    12-12-2016 01:36 PM
  2. belodion's Avatar
    I had similar trouble on a Lumia 1020. Uninstalling a few apps that I didn't want seemed to fix it. Does the trouble persist in Safe Mode in your case?
    12-12-2016 01:56 PM
  3. Rukbat's Avatar
    It could also be a dendrite in the battery - in which case the battery would have to be replaced.
    12-12-2016 04:56 PM
