1. AC Question's Avatar
    My device is draining battery so fast, i will try everything to do but there is something else.
    Actually when i checked that to mobile repair shop
    They said that its not the battery fault there is a fault of supply.
    Any idea about how to fix it??
    12-18-2016 11:59 AM
  2. MobileNick's Avatar
    I'm not sure I agree with the repair shop, unless they can show you proof (for example, show the output of the phone charging circuit and prove to you that the output current is too low). S3 is now several years old so if it is the original battery would not be surprising if that has gone bad now - the battery is often the first thing to go bad. Fortunately, you can get a new one on ebay, etc., for a pretty decent price - certainly cheaper than repairing your phone.
    I would take a chance and buy a new battery and see if that fixes it (unless like I said they have proven to you that the charging circuitry is bad). Just make sure to get an original Samsung battery - the aftermarket ones can start fires if you are not careful.
    12-18-2016 12:10 PM
  3. Rukbat's Avatar
    I would tend to disagree with your last sentence - both Anker and Hyperion are very good companies and both show batteries for the S3. (And "Samsung" batteries aren't always from Samsung.)
    12-18-2016 03:13 PM
  4. MobileNick's Avatar
    Agreed about those brands. By "...not careful" - I meant buying a no-name brand. You see a lot of those on ebay, etc.
    12-18-2016 06:16 PM
  1. Replies: 1
    Last Post: 12-18-2016, 01:35 PM
  2. Phone keeps disconnection my Bluetooth speaker
    By Koyoo in forum Ask a Question
    Last Post: 12-18-2016, 11:46 AM
  3. how i remove this adds from my htc phone?
    Last Post: 12-18-2016, 11:42 AM
  4. Is there a lightweight custom ROM for my Samsung Galaxy Trend 2?
    By The Strange Tester in forum Ask a Question
    Last Post: 12-18-2016, 11:24 AM
  5. Why my droid says I have new text message and I do not
    Last Post: 12-18-2016, 11:12 AM
