1. Nagi gabra's Avatar
    After i dropped it in water i turned it off and i put it on a bag full of rice 4 A week i then turned it on every thing worked fine exept charging......it takes 7 hours to charge on a fast charger ,changing the charging port didn't help ....
    12-18-2016 06:36 PM
  2. srkmagnus's Avatar
    Let the device sit longer in rice. There could still be moisture. If the problem continues then there's likely permenant damage to the port or board. If that is the case you'll need to send the device for repair.
    12-18-2016 06:52 PM
  1. Just got my S7 Edge...
    By flybub in forum Samsung Galaxy S7 edge
    Last Post: 12-19-2016, 01:48 AM
  2. Sprint Samsung Galaxy s7 Edge pricing
    By Ashton in forum Samsung Galaxy S7 edge
    Last Post: 12-18-2016, 09:50 PM
  3. S7 edge camera capture finger print?
    By Air Planet in forum Samsung Galaxy S7 edge
    Last Post: 12-18-2016, 03:33 PM
  4. Setting up Samsung Galaxy S6 Passcode.
    Last Post: 12-18-2016, 03:00 PM
  5. s6 active stuck at 83 % everytime i try backup thru SSS
    By Randall Brown in forum Samsung Galaxy S6 active
    Last Post: 12-18-2016, 11:42 AM
