1. AC Question's Avatar
    My lg g3 screen using 60% battery as time on 1 hour 23 minutes.. Is this happening because i changed my lcd or its something related to hardware? Help me please
    12-21-2016 11:28 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The screen will usually be one of the top battery users by percentage. The more important question would be how long is the battery lasting on one charge? Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    [GUIDE] How To Post Screenshots on Android Central
    12-21-2016 11:35 PM
  3. Nomanfbb's Avatar
    Sir the screen "time on is 1 hour 59minutes" the screen takes 62%.. I changed my battery as well as charger but still im getting this problem.. Battery backup is 4 hours if you are using continuously. If its on standby its giving 16 to 18 hours..
    12-22-2016 12:03 AM
  4. B. Diddy's Avatar
    Did you read my previous post? Posting those screenshots would be helpful if you'd like more advice, thanks!
    12-22-2016 01:23 AM
  5. Nomanfbb's Avatar
    1st
    12-22-2016 01:38 AM
  6. Nomanfbb's Avatar
    2nd
    12-22-2016 01:38 AM
  7. Nomanfbb's Avatar
    3rd
    12-22-2016 01:39 AM
  8. B. Diddy's Avatar
    Thanks for the screenshots. It looks like you're on track for a little over 3 hours of total screen-on time -- which certainly isn't great, but isn't necessarily that unusual. Did you used to get much better screen-on time?
    Also, it'd be good to see the graph (if possible) that shows the cell signal strength over the course of the battery charge. If you tap on the battery graph, do you get a fullscreen graph that has a cell signal strength bar along the bottom? If not, you might want to install GSam Battery Monitor, which does have a cell signal strength graph.
    12-22-2016 04:13 AM
  9. Nomanfbb's Avatar
    Sir have a look on this..
    12-22-2016 06:23 AM
  10. Nomanfbb's Avatar
    2nd
    12-22-2016 06:23 AM
  11. Nomanfbb's Avatar
    3rd
    12-22-2016 06:24 AM
  12. B. Diddy's Avatar
    Sorry, I'm still encountering a bug in the desktop AC forums website where some posted images don't show up. I know that these images can be seen if I use the app, but I don't have that currently in front of me. Are you following this procedure to post images? [GUIDE] How To Post Screenshots on Android Central
    EDIT: Ok, I took a look on the AC app. I don't see a screenshot of the cell signal strength graph -- did you find it? Also, I'm not sure why GSam is using that much battery itself.
    12-22-2016 12:22 PM
  13. Nomanfbb's Avatar
    12-23-2016 03:46 AM
  14. B. Diddy's Avatar
    That screenshot only shows the signal at that point in time. I'm talking about a line graph or colored bar graph that shows the signal over a period of time.
    12-23-2016 03:35 PM
  1. Poor battery life
    By kmra3332 in forum Motorola Droid Turbo
    Last Post: 01-14-2017, 05:21 PM
  2. Could use some advice on what to do next:
    By kwitel in forum Samsung Galaxy S7
    Last Post: 12-23-2016, 10:32 AM
  3. Can I extend my screen to another Android device?
    By Chriswaterguy in forum Android Apps
    Last Post: 12-21-2016, 10:51 PM
  4. screen resolution is bad
    Last Post: 12-21-2016, 09:53 PM
  5. can I use ue megaboom with my samsung phone
    Last Post: 12-21-2016, 08:25 PM
