1. AC Question's Avatar
    hello! Im desperate to get my archives on my Moto x gen 1 which has been turned off and have the power and the volume down button broken, someone knows how to turn it in or how to access the storage while he is off?
    I thought using and OTG cable and plugging an keyboard or an mouse, but I dont know if it will work.
    12-26-2016 02:01 PM
  2. Rukbat's Avatar
    You have to turn it on. Shorting the contacts where the power switch used to be for about a second will do that.
    12-26-2016 05:25 PM
  3. royanecodx's Avatar
    heya, try this method here : " "
    it works.
    also i donnow if its okay to reply with ytb vids , am new here! if its not okay , am sorry just wanna help.
    12-27-2016 04:00 AM
  1. Replies: 14
    Last Post: 04-04-2017, 01:45 PM
  2. the wifi on my lg stylus 2 is not turning on
    Last Post: 01-09-2017, 07:30 AM
  3. Replies: 1
    Last Post: 01-09-2017, 07:27 AM
  4. Best app to auto-disable/enable WiFi by location or router?
    By dhinged in forum General Help and How To
    Last Post: 12-26-2016, 08:29 PM
  5. receive group texts OK, cannot reply to them
    By Steve USA in forum LG G3
    Last Post: 12-26-2016, 01:44 PM
