1. AC Question's Avatar
    Hello everyone.
    My Galaxy S7 is not booting. Black screen. No Lights. Had about 90% battery when it failed.
    I have tried forced boot and recovery boot whith the volumes, home and power keys; All combinasons I could find on the net. For more than 1 minutes for each try. No signs of life.
    I plugged it to my computer via USB and windows found a device Exynos 8890 but could not install any driver. Windows did make the USB plugging sound. Windows also makes a sound when I press the phone power off and on. With slighly different tones.
    I have downloaded Samsung latest USB drivers to see if I could go further, but than does not change anything.
    Any help from anybody ?
    Thanks !
    Ben
    12-29-2016 07:32 PM
  2. Rukbat's Avatar
    Plug the charger into the phone. Let it charge at east overnight. See if it comes on then. (If the battery threw a dendrite at 90%, it would now be at 0%, and it's going to take time to burn the dendrite off and recharge the battery. If it shows any sign of life after that, have the battery replaced. [Unfortunately, even though dendrites are factory defects, they're not covered by the warranty.])
    12-29-2016 10:58 PM
  3. maryus1998's Avatar
    Hello brother have solved the problem with s7 galaxy, and I have the same problem as you, if somehow you solved it, please tell me some how you solved it.
    Thank you very much!
    02-23-2017 03:05 PM
  4. B. Diddy's Avatar
    See response in your other thread: Samsung Galaxy S7 dead,black screen
    02-27-2017 02:45 AM
  1. Replies: 5
    Last Post: 01-03-2017, 12:36 PM
  2. Is this phone worthless due to low internal memory?
    By markmall in forum Moto E (2014)
    Last Post: 12-29-2016, 10:47 PM
  3. How to I set up my asus tablet to project on my smart tv
    Last Post: 12-29-2016, 10:24 PM
  4. Replies: 1
    Last Post: 12-29-2016, 09:53 PM
  5. Notification when text is received
    Last Post: 12-29-2016, 09:51 PM
