S7 edge how to check if your /system is protected?
Lum1n
6
I recently Rooted my phone and wanted to change my lock screen sounds. But I can't change my /system to R/W. Root Explorer no longer has the R/W button and SuperSU latest versions are system-less. I've tried terminal emulation and hours of googling to no avail. I had a reply saying that my /system could be protected. So how do I check if my /system is protected? If so how to i remove the protection.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
If you have root access, run an app like Root Browser to change system files. (Don't change the name of the /system folder or you'll never run the phone again, until you reflash the ROM (and lose everything that you've out on the phone).
MickTavia
