1. AC Question's Avatar
    after upgrade it's android , while it charging, frequently turning on and turning off automaticly. What should I do? .Before upgrade it dosen't have this problem.
    01-16-2017 01:35 PM
  2. belodion's Avatar
    First, have you tried a different mains socket, charger, and USB lead, to try to exclude a charging fault as the explanation?
    01-16-2017 02:54 PM
