1. AC Question's Avatar
    I have a Samsung Gear S2 smart watch and I am trying to find a Dual Sim Android phone that will connect to it. I have tried a Samsung A3 duos and a Samsung J7 Duos but neither has worked. I can't keep buying phones and sending them back, can anyone please help.
    01-19-2017 04:17 AM
  2. chanchan05's Avatar
    Did you download the Gear app? You need that to work with the Gear S2.
    All I can say for certain is that the S series and Notes work with the Gear S2. My S7 Edge is dual SIM and it would work with the Gear S2.
    01-19-2017 04:37 AM
  3. deggsy999's Avatar
    Hi, thanks for your answer, I am already using the watch with a S5 so I understand that the gear manager software is required. I was hoping that I wouldn't need to go to the expense of a S7. I am wondering if it's something to do with the dual sim part of the software because the watch should work with both the A5 and the J7.
    01-19-2017 07:34 AM
  4. chanchan05's Avatar
    It's not the dual sim software. My S7 is dual sim.
    01-19-2017 07:52 AM
  5. deggsy999's Avatar
    What's the country of origin of your S7? My A3 was UAE (ebay) and I was told by Samsung that's why it didn't work.
    01-19-2017 08:13 AM
  6. chanchan05's Avatar
    Philippines. All S7 and S7E here are dual SIM, and they sell the Gear S2 here for it as well. One of my friends is actually using the original Gear S with his dual sim S7 Edge and its working fine.
    01-19-2017 08:35 AM
  1. [App] [4.0+] Have a break and laugh with Mr Jokes
    By sylsau in forum Android Apps
    Last Post: 02-13-2017, 03:40 AM
  2. Ho to Root Samsung Ji Ace
    By Bumperbee in forum General Help and How To
    Last Post: 01-23-2017, 08:41 AM
  3. Replies: 1
    Last Post: 01-20-2017, 03:51 AM
  4. SIM card not detecting / network setting not working
    Last Post: 01-19-2017, 03:37 AM
  5. Replies: 0
    Last Post: 01-19-2017, 02:09 AM
