1. AC Question's Avatar
    i have Motorola ultra mini whenever i make a call after it i cant cut because caller id (properties) goes hide
    similarly when someone call me i cant see who is calling even i cant receive a call
    because all calling properties are hide
    01-23-2017 06:24 AM
  2. sfoLAX's Avatar
    Welcome to Android Central.
    Do you mean the screen stays black after a call ends, or the phone app doesn't appear so you can answer or end a call.
    Try clearing the Cache partition (details available), just restarting the device or go to Settings - Apps - All - Phone (there may be more than one) and open to Clear Cache. Clear data also if that doesn't work. Contacts are not saved there. If you can Uninstall Updates there the Play Store will update it.
    You may also have a Phone/ Messaging storage app in the Apps list where you can clear Cache.
    01-23-2017 11:11 AM
  1. Replies: 1
    Last Post: 04-11-2017, 05:17 AM
  2. How to block xuixd.com
    Last Post: 01-23-2017, 06:23 AM
  3. unable to clear recent apps
    Last Post: 01-23-2017, 06:19 AM
  4. What is the best way to change my voicemail my android phone?
    Last Post: 01-23-2017, 05:52 AM
  5. I cant close tabs on my samsung galaxy s 3
    Last Post: 01-23-2017, 05:28 AM
